Creating custom selection scripts
Command |
Path |
Custom Selection |
Tools |
Custom selection scripts allow you to select or deselect objects in a file according to specified criteria. No scripting knowledge is necessary.
The layer options must be set to Show/Snap/Modify Others to select objects on another layer.
To create a custom selection script:
Select the command.
The Custom Selection dialog box opens. Select the desired options for the operation.
Parameter |
Description |
Select |
Selects objects matching the specified criteria without affecting the selection status of other objects |
Select Only |
Selects objects matching the specified criteria and deselects all other objects |
Deselect |
Deselects objects matching the specified criteria without affecting the selection status of other objects |
Execute Immediately |
Performs the specified operation immediately upon exiting the dialog box; the operation criteria are not saved for future use |
Create VectorScript |
Saves the criteria and command options as a VectorScript that can be reused, but does not run the script |
Create Python Script |
Saves the criteria and command options as a Python script that can be reused, but does not run the script |
Specify the criteria for the operation as described in The Criteria dialog box. Click OK.
If you selected one of the script options, you're prompted to select a palette for the script, and then to name the script containing the commands. The script then displays in the specified palette; double-click the script to perform the operation. See Creating and editing script palettes and scripts.
If you selected the Execute Immediately option, the objects are selected or deselected.
